tooserious
I have Mimaki JV3 130 SPII and was wondering if anty one is using Bordeaux or Mega Ink Instead of the SS2......Or if you have a Suggestion Thank you
All 3rd party inks are good until your 1st bad batch of ink, carts, or chips (mimaki/mutoh). After that, let's hear the reviews.
My .02
Those nazdar inks are great....no color shift problems...they are plug and play no flushing the machine. No venting. Colors actually looked a little brighter when next to each other on same files. Inks seem a little more durable....a lot of positives for less.
do they come in cartridges and if so what is the cost?
Some quick sample pricing I found. Pretty good deal. Heard some great things about these so far.
http://www.martin-supply.com/assets/infosheet/Lyson/Martin Lyson Starter Kits.pdf
so you just load these inks as the oems need replacement? seeing that they say there will be virtually no difference in profile I can only think this is the way to work them? I am hesitant yet interested. Anybody in the great white north selling these?
Not sure about Canada, but the Nazdar inks do work quite well, the only issues is that the machine requires more TLC in dry conditions and a little solvent in the caps over the weekend to keep things clean...I suspect the reason for this may be a higher solvent content (thus more crusties), but the colors are as close as I have seen to OEM and there are no harmful effects from top loading. Nazdar claims it is compatible with the OEM.
The only other issue I have seen is an misting or overspray when the carriage is in the high position.
what do you mean solvent in the caps over the weekend. I do a nozzle wash every friday, is that the same or do you actually let the heads sit in the solution for 2 days?
+1do they come in cartridges and if so what is the cost?
