This is a miter cutter for plastic edge trim...
Discussion in 'Miscellaneous Hardware' started by Gene@mpls, Mar 12, 2009.
  1. Gene@mpls
    Gene@mpls Very Active Member
    2,017
    92
    48
    Jun 17, 2003
    Blaine, Mn
    that I bought years ago and cannot find now. I would like to have
    another of them. Anyone recognize it? The brand name is 'Lowe' and
    the anvil that the blade cuts against was the length of the blade before it was
    'repurposed' :rolleyes:. Thanks Gene
  2. jiarby
    jiarby Major Contributor
    4,513
    Probably a framing tool.... look in the united framers catalog.
  3. markymarkmfb
    markymarkmfb Member
    115
    Jan 30, 2009
    Walled Lake, MI
    Wensco carries a notcher for edge cap but they are a little pricey.
  4. high impact
    high impact Very Active Member
    We purchased our v notcher from RJ Sign supply but like markymark says they aren't cheap.
  5. Gino
    Gino Premium Subscriber
    33,510
    2,398
    113
    Jun 7, 2006
    PA
    Try Glantz.
  6. jscarl
    jscarl Very Active Member
    1,987
    That looks just like the pruner tool for trimming limbs back and pruning grapes. I got it at Lowe's. Think $5.00.
  7. TheSnowman
    TheSnowman Major Contributor
    6,919
    41
    48
    Aug 28, 2007
    Indiana
    If it was me, I'd just distract Mark w/ a Pizza and a box of Donuts, and go take his for a while!
  8. high impact
    Depends on the kind of pizza.
    On second thought, I'm a push over! It's the REAL boss you need to worry about! Her name is Mrs. High Impact!
  9. BobM
    BobM Very Active Member
    2,148
    45
    48
    May 31, 2008
    Cape Cod
    Dick Blick Studio spring catalog, page 73. Item #p35106-1000. $18.39.
  10. Gene@mpls
    2,017
    92
    48
    Jun 17, 2003
    Blaine, Mn
    Thanks to all- I figured someone would recognize it. Gene
  11. sfr table hockey
    sfr table hockey Very Active Member
    1,212
    Jan 24, 2009
    Alberta
    You will find them at picture framing suppliers as well ( used for small fillet frame for inside the glass side ) They will be a lot more money ($50-$80) there than at a place like noted above. Not sure if they are any better quality. I am using one that is from a liquidation place (princess auto) and it works fine.
  12. Gene@mpls
    2,017
    92
    48
    Jun 17, 2003
    Blaine, Mn
    HjeffN was kind enough to point me to Home Depot carpet dept- exact tool
    (different brand name though) with a carpet cutter type blade that works
    even better than the original. Thanks Gene
