This One Is Killing Me
Discussion in 'Fonts and Typography' started by iGraphics&Designs, Apr 3, 2013.
  1. iGraphics&Designs
    iGraphics&Designs Member
    29
    Anyone know what font "Whistle Stop" is in? Thanks for any help.
  2. Pixels Are Bad Mmmkay?
    Pixels Are Bad Mmmkay? Very Active Member
    It looks very similar to Bounce Script, only italicized.
  3. iGraphics&Designs
    29
    Finally found it - Freehand 575 BT
  4. SignProPlus-Chip
    SignProPlus-Chip Active Member
    603
    1
    16
    Feb 19, 2012
    Bluffton, SC
  5. Fred Weiss
    Fred Weiss Merchant Member
    20,565
    423
    83
    Sep 11, 2003
    Olympia, WA
    No match but it definitely isn't Freehand 575.
  6. mark-s
    mark-s Active Member
    967
    29
    28
    May 11, 2005
    SoCal
    SignPainter is close.
    The jpg looks like embroidery.
    mark-s
  7. iGraphics&Designs
    29
    Everything matched except for the W and S. The W was close enough that the customer was okay with it, and I changed the S to a different font and added some slant to get it. Thanks for all the help guys.
  8. WildWestDesigns
    WildWestDesigns Major Contributor
    6,570
    324
    83
    Sep 27, 2010
    5
    It looks like the simulated rendering that most programs have the ability to give a bitmap capture of the design. Based on how it looks, I think it was rendered from the WINGS program. Might be one of their standard fonts. It doesn't seem to be a Wilcom one.
  9. Cyw
    Cyw Member
    120
    Oft times, embroidery keyboard fonts won't exactly match their ttf equivalents.
    We sometimes tweak areas to make them more embroidery 'friendly'.
    Good you found something close, that satisfied your customer.
    In the process, I hope you also adjusted that kerning nightmare.
    Thats one real masterpiece, isn't it?
    oh boy
  10. WildWestDesigns
    6,570
    324
    83
    Sep 27, 2010
    5
    Yep, that's true. In the case of this particular font, two things come to mind of possible areas where a direct conversion may not work.
    Kerning on a block font is typically 10% of height,which may or may not be the kerning of the TTF version. For the scripts, there usually isn't any spacing as a standard. All of that can be changed though depending on software.
    Also depending on what size the font is, the serifs may be the same stitch angle (this aren't, but they can be) as whatever they are attached to. A auto conversion from a raw stitch file to vector may yield less then desirable shape (I wouldn't suggest an auto conversion based on a raw stitch file anyway) in that case.
    Sorry for being a :thread
Similar Threads - Killing
  1. Abraxas Aguilera
    6
    936
