Tiff vs eps
Discussion in 'Roland' started by jason91, Jan 14, 2011.
  1. jason91
    jason91 Member
    163
    2
    18
    Oct 14, 2010
    knoxville
    I've got a couple colors that I have been exporting out of coreldraw that are giving me problems. Orange and purple. The purple I've got is awesome if I export it as a tif (rgb) and print...However I can export the same color as an eps(rgb) and its a totally different color?? Almost a blue....
    The problem is the orange I like is an eps (rgb) and I can't get the orange tif (rgb) to look as good as the eps. When I have to print these 2 colors together I'm stuck??? I usually export everything as an eps, because I do alot of cutcontour stuff. I've tried to match the tif printed purple to a eps printed purple with no luck? The tiff color just seem more saturated? Why is that?? I can get the eps purple the same tone, but it' not as bright and shiny?? Any ideas?
    Oh.... and the orange I'm trying to get is to match aluminum orange?
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    rgb bitmap the purple parts, and export everything (with orange still vector) as an rgb pdf...try it
  3. jason91
    jason91 Member
    163
    2
    18
    Oct 14, 2010
    knoxville
    I can't seperate them...they are in the same decal or wrap? Do you mean turn the purple into a bitmap iside of coreldraw?
  4. J Hill Designs
    15,549
    16
    yes but leave orange vector and export as rgb pdf...should work unless purple is above orange...
    was just a thought
  5. Si Allen
    Si Allen Very Active Member
    2,146
    1
    Yup!
  6. jason91
    jason91 Member
    163
    2
    18
    Oct 14, 2010
    knoxville
    I'll try that...and see what happens...thanks
  7. jason91
    jason91 Member
    163
    2
    18
    Oct 14, 2010
    knoxville
    can't export or save as a pdf out of corel?
  8. Tony McD
    Tony McD Member
    458
    2
    18
    Sep 13, 2006
    Camdenton, Missouri
    File>publish to pdf
  9. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    When you publish as pdf be sure your page size in corel is the size you want to print. Like if your image is 13" wide and the page size is the 8.5x11 it won't work. Use the custom page size and set it to what you want.
  10. CentralSigns
    CentralSigns Very Active Member
    1,338
    Jan 23, 2010
    Golden BC
    Versaworks really needs to address the color profiling problems it contains. It's really flaky isn't it. Always something that isn't right.
  11. Mosh
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Versa works GREAT for basic sign printing. NOT so great on making color true prints. It is what it is.
  12. jason91
    jason91 Member
    163
    2
    18
    Oct 14, 2010
    knoxville
    will the graphic be as crisp as an eps or a tiff....becuase i don't see how it can be...the graphic goes from a 1gb (tiff or eps) to a 100mb pdf....It's got to be losing detail (resolution) somewhere?
