time out
wes70
I have flex 7.6 v2. Just went to send a file to cut the following shows up:
"Connection to Production Manager timeout"
I checked my Firewall settings and that is fine. Restarted computer and that didn't help. Should I re-install Flexi?
Any ideas?
I
GregT
Mine has been doing that for about 6 months. I now close PM before I send anything to be cut. Tech help says I need to update to Flexi 8. Not gonna happen
cOrKinSA
Thats wierd because that was happening to me as well. After many times of fumbling around I found if I remove and replace the dongle key right before I load the "PM" it works properly. Hope this helps you too.
wes70
This has happen to me before, but last time all I did was restart the computer.
I did get working today after 3 restarts and resetting preferences. For now it works...........but it'll happen again.
Drip Dry
Go to "EDIT > PREFERENCES"
Under tools > goto "CUT/PLOT"
Uncheck the box that says "USE TCPIP"
Send the job.
If that dosen't work, then do a "Clear Preferences" and then go back and uncheck the box.
JT
Service Sign Co
Can't say for sure with Flexi, When that happens check the Queue folder in Explorer, there should only be 1 file there. That was a problem with Omega in the past & and clearing the folder was the solution
wes70
Tried to use flexi today and Productiom Manager wouldn't even open. I un-installed flexi an re-installed. Works great now! For how long? Who knows!
