Slow down..........learning curve........
I run this baby with the covers off at the righthand side so I can see what happens while the machine is cleaning.
Most important with these machines is to keep the lines clean and the sponge in the cappingstation wet but do not store it with strong cleaning fluid as this will swell the foam which then contact the head and cause crosscontamination.
Waste lines to the waste bottle and the lines from the cappingstation to the pump all need to be open.
If you have some cleaning fluid and a syringe push this through the lines or if no fluid listen of the air passes through.
If you bougth this machine used you have to run this over once to make sure all lines are clean.
If you run a cleaning cycle check if the ink flows through the waste lines. Black and color have different waste lines.
If it does not then it is not the fuse.
Lot of ifs..............
In basic this machine is very simple to troubleshoot if you know what you have to do.
Pull the power cord if you work on the machine. That is the only way not to shortcut and blow the fuse.
Paco
