Question Tips for Keeping Dirt off Plastic....
Discussion in 'Tips & Tricks' started by KeithMan, Apr 28, 2020.
  1. KeithMan
    KeithMan Member
    43
    Sep 1, 2019
    Missouri
    We have become inundated with a few clients that want everything printed on 20 and 30 pt polystyrene. We run it on our Epson S40600 and the results are fantastic. The only real problem is that it attracts lint, dirt and hair like a magnet. We currently take each 4x8 foot sheet and wipe it down with alcohol and then quickly print it trying to make sure no dirt gets on it. With the prints being heavy coverage though we have had several get ruined by a hair or particle of dirt.
    What do others do in high production environments to deal with this issue?
  2. myront
    myront CorelDRAW is best
    1,493
    289
    83
    Dec 3, 2015
    Niceville, FL
    Might try a static guard spray. We used to use it when printing directly to pvc. We also have a wide type of roller that's sticky to run over the sheet. Kind of like a lint roller. Comes with a tear off sticky pad to "renew" the roller with.
  3. myront
    1,493
    289
    83
    Dec 3, 2015
    Niceville, FL
  4. KeithMan
    KeithMan Member
    43
    Sep 1, 2019
    Missouri
    Thank you.
  5. CanuckSigns
    CanuckSigns Very Active Member
    3,430
    397
    83
    Nov 11, 2008
    Ontario
    Can you print directly on styrene with an Epson s40600? I've got an s80600 and never considered this. We print on a cheap matte vinyl and apply with our rolls roller.
    Are these standard sheets of styrene or some kind of roll stock made for printing?
  6. player
    player Major Contributor
    4,915
    189
    63
    Apr 24, 2006
    Toronto
    How does one clean this roller?
  7. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,358
    286
    83
    Apr 11, 2012
    Australia
    I've seen two versions. One just rinses under water, the other used a pad of adhesive paper which you roll it onto and the debris gets transferred to it.
  8. KeithMan
    KeithMan Member
    43
    Sep 1, 2019
    Missouri
    Yes. We occasionally print on .030 styrene, but it is kind of a pain in the rear. We mostly use .020 from Grimco and it runs great. The print is durable and it looks great. You do have to make sure it doesn't come off the paper sensor since it is so rigid. I put a sheet of paper over it to trick it.
    Our clients use them in sign holders and like the fact they can be rolled up yet are semi-rigid, water proof and easily cleaned.
    I would give it a quick wipe down with alcohol, as some of the plastic seems to have a chemical residue on it that will cause strange patterns in your prints. Plasticizers???
