toomeycustoms
Will be moving 6 hours north next Thursday and we will be renting a 16 ft box truck with a liftgate. Only machine I'm worried about is our Roland SC-545. It will be unplugged for about 7-8 hours. I've found some info searching and need some additional info.
1. Make sure head is secured in place. I have the blue bracket and the head will be secured
2. Empty ink bottle and plug the drain tubes. Is it ok to empty the drain tank and just tape it in place without plugging the tubes?
3. I'm trying not to waste ink and flushing it out. Will the caps and heads be ok for 8 hours without power? I have read something about putting some cleaning fluid on the caps? The only cleaning fluid I have is Triangle brand "Flush". Is this the same stuff or is there special fluid? How much fluid to I put on?
4. Do I remove the ink cartridges? Do I need cleaning cartridges?
5. Where should I strap the machine without causing damage? Just at the base or are there any special mounting points on the upper part of the machine?
Any other tips you can provide or step I am missing?
