Tips on redrawing this
Lindsay
Wondering if someone knowledgeable person could give me a few tips on how to recreate the yellow design in Illustrator CS2. Other than drawing each segment. Need to end up with a EPS/AI file for cutting.
Any help appreciated.
TheSnowman
Can't see it at all because it's so tiny...but might be something you could send to the Vector Doctor if it's a decent size file.
Fred Weiss
I wouldn't redraw each segment. The best way to do it is to set each of the circles down and then perform Pathfinder knockouts and merges. It's a good practice job to learn how those tools work.
Approach it as if you are a draftsperson using a compass with a pencil and and eraser.
Lindsay
Thanks Fred for the tip.
I'll tackle this tonight when things are quieter.
Sorry about the small image. Best I had.
iSign
rather obvious, I'd think... but just in case...
...rotate it first, then lock it, then set some horizontal and vertical guidelines... then you should be able to draw a pretty quick oval... then you should be able to use repeats of that in many (or all?) cases...
then do as Fred suggested!
Lindsay
I previously got as far as the ovals and repeats.
Where I got stuck was how to create the tapers on each segment.
Without doing it the hard way that is.
Thanks everyone for your assistance.
I'll try the suggestions later today.
