Question Tips to cut coroplasts quick
C
ColoPrinthead
Guest
Does a stomp shear cut the coro? We've tried cutting abs sheet with ours and it wouldn't do it. It just bent over the edge and got stuck.
The one we had for coro was much lighter than what we used to ACM and Aluminum, so you could get a clean enough cut with a quick stomp because the blade was much lighter. I don't recall ever seeing anything to messed up from the cut that couldn't be cleaned up or acceptable for a job that was using coro.
[QUOTE="Employees scared of a panel saw?? Remind them that they have 9 spare fingers. Don't get your wiener in it and you'll be fine.[/QUOTE]
Ha. Reminds me of some of the larger litho shops I've been to where you have safety reminders in your previously injured corworkers.
