phototec
Window perf fogging in the desert:
Here's a thought, don't apply the laminated window perf to the glass in a non-controlled environment, trapping moisture under the laminated window perf and allowing it to fog up later.
Only apply the laminated window perf in a humidity controlled environment (according to the manufactures recommendations), then you won't have moisture trapped under the window per that will cause fogging!
I use ORAJET 3675 Window Graphics Film, and it is recomended to laminate the window perf with Oraguard 297GF and either let the laminate extend past the edge of the perf all the way arround the perimiter of the graphic or apply a strip of laminate (.4 to .5 inch wide) all around the perimiter overlapping the edge and the receiving surface to seal out MOISTURE and DIRT.
This will not only improve the adhesion of the edges to the surface but also effectively prevent any penetration of humidity and dust.
I always follow the manufactures reccomendations for installion, here are the recommendations:
Freshly printed films should be spread out and left to dry for 72 hours before lamination.
It is recommended to exclusively apply the Window Graphics Film together with Oraguard protective films in a laminated form recommended by ORAFOL.
To ensure a high-quality of application, the film should be applied at a temperature of at least +10°C in a dry and closed room. The glass substrate should be left in the room for several hours prior and after application in order to allow the receiving surface to adjust to the application conditions and to achieve the best possible adhesion result.
