Transistor for Roland
bovegas
Anybody know if I can check A1746 transistor while its on the board or I have to take it out in order to check with o-meter.
Thanks in advance
signage
That depends on the meter you are using. There are meters that do not load down circuits to check.
bovegas
Thanks for replay but this article doesn't mention if you can check transistor while its still soldered to the board. I am not sure if I have to take it out of the board to test.
signage
If you do not have a schematic with test points and values shown, you will need to remove to test. As I stated above even if you have such schematic you will also need an electronic meter.
Jim Hancock
Old School Technician
If you are checking it because you are blowing fuses, then you do not need to remove it from the board, as it is shorted and will read zero ohms across 2 legs, even while still in the board. If you are checking it for any other reason, you will nedd to remove it from the circuit to get an accurate reading of its status.
bovegas
Thanks Jim, thats the answer I was looking for. Now is there any way I can check if head is causing fuse to blow with O-meter?
Thanks again
Jim Hancock
I would need to know exactly which model you have to advise you. It would involve hooking the suspected head up to a different channel on the printer. You are now entering an area that should really be dealt with by an experienced technician on-site. I don't know your level of technical expertise. It is also possible it is a bad data cable between the head and carriage board. There are other questions to be asked here, such as have you had any head crashes that could have damaged the head.
Jack Knight1979
Jim is a good guy. He worked with me a last year to get a bad roland going.
I've rebuilt my headboard three times now. If you can't get it figured out pm me.
