transparent background PS to AI...
Discussion in 'Adobe' started by cha88, Dec 1, 2010.
  1. cha88
    cha88 Member
    160
    May 14, 2010
    Watertown
    I am having issues getting my PS work into AI without a white background... in PS i have the background seperated from the image but when in place it in AI it has the white box around the image again...i have tried several things but to no success...
  2. spur
    spur Member
    30
    Jun 4, 2010
    North Carolina
    Save it as a .png file after you remove the background.
  3. cha88
    cha88 Member
    160
    May 14, 2010
    Watertown
    i have tried that and it tells me "could not read the file because the plug-in could not understand the file"
  4. Bigdawg
    Bigdawg Just Me
    7,459
    133
    63
    Jun 8, 2005
    Sunny Florida
    did you save it as a psd file? Did you make sure the transparency and not your white background is showing in photoshop? If so, then open the file and click on convert photoshop layers to objects when the dialogue box appears.
    I do it pretty regularly...
  5. jc1cell
    jc1cell Active Member
    596
    Jun 11, 2007
    76137
    +1
  6. cha88
    cha88 Member
    160
    May 14, 2010
    Watertown
    thank you for your quick replys... i have tried so many things im not sure why that did not work originally... the problem now that the backgroud is not showing...is that i need to add the cutcontour swatch to the outline of the object... but the object has a box around every layer...what is my next move? thanks
  7. Bigdawg
    Bigdawg Just Me
    7,459
    133
    63
    Jun 8, 2005
    Sunny Florida
    you have two choices.... go back to photoshop and use the magic wand to select the transparent area... then go to select---->inverse. Then go to your paths and select "make work path" and enter .5 in the next dialogue box. Save your path and resave the file. Now when you import into Illy, that path will also import. BUT... it is probably a little jaggy from the magic wand...
    You can then either use the smooth or simplify tools to fix the path in Illustrator. Or... sometimes its easier just to draw the path in AI by hand to begin with.
    S
  8. TheSellOut
    TheSellOut Very Active Member
    1,355
  9. Locals Find!
    Locals Find! Very Active Member
    2,732
    1
    36
    Oct 17, 2010
    Fort Myers
    Save the file as .gif that will take out the white box if you have neutralized the background. I do it all the time and that is the easiest way I know how. Just have to save it as an RGB vs. CMYK to preserve the neutrality.
    Then just import it into illustrator and your good to go.
Similar Threads - transparent background
  1. dasigndr
    10
    678
