Hi
Got a cascade of troubles that happened; my overview
I replace DX5 head about 2 months ago, i kept the dampers that were already in the machine, replace captop + pump (lines were broken) with a generic one.
Printed fine. I had some sparetime, though replacing the dampers would be a nice intervention. Replace the dampers by unhooking the attached one from the clamp, unplugged it from the head and hooked up a new one to the clamp and plugged it back in the head.
I did a fillup via the menu but nothing seemed to happen. Did a discharge&wash and the tubes did went clean but still not like i hoped.
I began to suspect that my pump was having issues, so opened the machine, and noticed washing fluid dripping out of the bottom of the new (generic) pump.
Opened the pump and noticed the two tubes were already broken. Remove the pump, serviced it with new tubes and installed it again.
After discharge & wash i restarted the filling procedure by the printer, but it "kinda" worked , Problem is, there was alot of air bubles in the inktlinks. I removed the dampers, opened the valves and pulled out the air , lines are airless now. And nothing much was discharged the first time.
Restarted a fill ink, but it just won't start..
As final parking solution i now filled my head with cleaning solution just to avoid my head goes bad, when cleaning it nozzles are all ok.
I assume i did something wrong with replacing the dampers, are the dampers ready for the bin and should i order new ones? Or is there a way to reuse the new dampers .. help is appreciated since my machine is down now
