Trouble gluing polymetal to mdo
Discussion in 'General Signmaking Topics' started by Salmoneye, May 26, 2011.
  1. Salmoneye
    Salmoneye Very Active Member
    1,243
    Having trouble gluing dibond to mdo/omega... using PL1 premium, liberally and then spreading with a notched trowel putting two panels together and then weighting them. Not getting great results. Am I missing something?
  2. Billct2
    Billct2 Major Contributor
    7,489
    651
    113
    Mar 12, 2005
    New England
    Did you scuff & clean the panels first? How long dry time?
  3. Salmoneye
    1,243
    We are having almost no humidity here, 12 hrs dry time looking for light bond, did scuff one panel and not another and there does seem to be a slight difference. I am surprised though as it doesn't recommend scuffing smooth surfaces (although it always makes sense) and it says that is is good for plastics that are many times smooth. I guess that I was expecting a little more. Also what does everyone use for gluing hdu to an mdo backer?
  4. Kottwitz-Graphics
    Kottwitz-Graphics Very Active Member
    1,390
    78
    48
    Sep 25, 2006
    Ridgely, MD
    The only way that I personally bond MDO and HDU is to put the MDO inside the HDU.
    I rout out the area where the MDO is going to go, and encase it in West System Epoxy. That way water won't get to the wood to cause any rot.
  5. Fitch
    Fitch Member
    369
    1
    Sometimes... when substrates dont "match" it is far better "glueing" the fastening mechanism together. Try looking beyond the two substrates to what will adhere to each of the substrates... then "glue" the fasteners together.
    I know here in Oz that PVC will not glue to polyurethanes. But PVC glue adheres to polyurethane glue.
    Get my drift? Think 4 substrates - not two.
    Cheers - G
