Trying new vid cards! got quad + 2 gigs!
Discussion in 'Computer Hardware' started by bullcrew, Jun 7, 2006.
  1. bullcrew
    bullcrew Member
    153
    Here's the situation, I run photo/illus cs2 and flexi pro I load big files (I meen huge) and it gets lines when moving it.
    Yesterday I put (2) 1 gig ddr 3200 ram modules in along with a nvidia quadro fx 540. I have a amd 2600 (being upgraded to 32/33) and a 7200 rpm hard drive, I have run it a little and so far it screams.
    What video card seems to be the best for printing and graphics.
    G-force/pny nvidia quad fx 540 or ?.
    Need help or options.
    Is the card overkill and what other card would be just as effective.
  2. Cadmn
    Cadmn Very Active Member
    2,859
    bullcrew your question is a good one, the problem lies herein opinions on cards are like opinions on software I think www.Tomshardware.com offers actual testing & data. their opinions are respected on the net
  3. Sabre
    Sabre Member
    375
    I did as much research as I could find on this subject when I built my design machine and I could not find any definitive tests or results. I found a lot of opinions that pointed us towards the Matrox line. I cant tell you which one is best for certain applications; we went with the Parhelia and are pleased with it's output.
    Unfortunately, most sites are testing 3D rendering performance and antialiasing and the like for game performance. Resources are extemely limited when it comes to testing for colour purity or the stuff that's important to a graphic professional.
  4. alanzhao
    alanzhao Member
    163
    I built my dual CPU workstation (Intel XEON 2400), the onboard graphic card 512MB and 1G memory work just fine with some over 2MB .bmp files.
  5. bullcrew
    bullcrew Member
    153
    Yeah the vid card is a considered a graphics pro workstation.
    128 bit floating point pipeline
    12-bit sub pixel
    8 pix per clock
    programmable gpu
    agp 8x/4x and texturing support
    dual monitors
    digital output
    2048x1538 at 85hz
    etc... yady yady ya!
  6. 2NinerNiner2
    2NinerNiner2 Very Active Member
    1,122
    Mar 21, 2006
    Calgary, AB
    I did the same thing last week; 2 x 1GB ddr 3200 on a new ASUS motherboard. Can't recall the model (I'm writing this from my iBook while having my requisite coffee at my fave sidewalk café :) But what I'm wondering is, if you are manipulating large files like that, do you then design at full-size? I am not familiar with Flexi, but I routinely end up with multi-GB files from ColoRIP, but after it has scaled up my Corel or PS files that I design at a manegable size. Just wondering which way is better.
  7. alanzhao
    alanzhao Member
    163
    Just wondering if you guy could really actually end up with "multi-GB" files? How many files are there? What kind of files are they?
  8. mfarney
    mfarney Member
    70
    File Size
    We Create and Print alot of Billboards and Buswraps. Some are huge even before they are ripped. After they are ripped some are now 4, 6, or 8 files containing the color separations. Our Printers are file mode printers so the press operators drag the files into a program after they are ripped.
    Multi GB files for us are very common.
  9. 2NinerNiner2
    1,122
    Mar 21, 2006
    Calgary, AB
    OK...back at the PC now. Here's the specs:
    ASUS K8N board with 2.01GHz AMD Sempron 3300+, 2GB 3200 DDR RAM, nVidia GeForce 5200 AGP 8X with 128MB, Acer AL 1912 19" LCD.
    With this setup, I have had no lag or display issues when dealing with very large files in Corel or P-Shop. I was a bit amiss in my earlier post in that the Corel and P-Shop files can get up to 500 - 700 MB (after being exported as EPS), but when RIPPED, are 2 - 3 GB in size. But the RIPPED files are not 'manipulated' per se, just opened in the output queue and sent to the SP-300.
    'mfarney' - do you design the boards and wraps at full size or scale them up in the RIP?
  10. Pro Signs & Graphix
    Pro Signs & Graphix Very Active Member
    2,477
    Here is the bottom line. There are two major video chip manufacturers. ATI and nVidia. ATI gears towards professional businesses, and their apps. nVidia gears towards entertainment, movies and gaming.
    Both are good cards, but we have better luck, meaning no conflict issues with ATI. Most will never know the difference. As for video memory, most will do just fine with 128. We run 256 only because "I" have no intention of changing next year, and most likely for another 3.
    System memory is also an issue, that can affect the whole deal. Most have 1GB, and never really "use" it. More never hurts, but isn't necessary. I am getting ready to drop another GB, on top of the current 1 GB, ONLY because I like to open Corel, PhotoShop, and a couple other memory hungry apps at the same time.
    The point - 1gb memory + 128 video + 1 app at a time, should be sufficient.
    Techman, who truly worked on these "anchors" would be able to better elaborate - if he agrees. :smile:
  11. bullcrew
    bullcrew Member
    153
    I don't play games, but am familiar with the g force cards and the pny graphics card is made for cad/3d/graphics and rendering. My concern is that is it better for graphics than a gforce?
  12. Cadmn
    2,859
    with the right program /setup all should be able to be tweeked to give color of print = to moniter color
  13. bullcrew
    bullcrew Member
    153
    I said $cru it and got a asus amd 64 x2 board coming in and 2 IBM hard drives in raid 1 configuration with max memory. I believe it's 4 gig ddr.
    Overclock with a bigger fan on cpu as well as an aluminum case (laim li) with the oversize power supply and 5 fans.
    Built a monster before but it's been a while since so I am until today
  14. Bobby H
    Bobby H Very Active Member
    1,840
    99
    48
    Feb 4, 2005
    Lawton, OK
    If you're doing strictly 2D stuff, Matrox is by a very wide margin the best out of anything available.
    The 3D thing in a production environment can become an issue if you need any OpenGL acceleration. 3D gaming is not the only thing which demands this.
    If you mess around with 3D applications like Maya or Lightwave3D then a Quadro card can be a good investment. Also, Adobe After Effects demands heavy utilization of RAM and OpenGL functions in video cards. AE is a pretty crucial tool in creating motion graphics for things like full color LED electronic message centers and POP kiosks with video displays.
  15. bullcrew
    bullcrew Member
    153
    This card has: programmable gpu (microsoft open gl 1.5 direct x 9.0), agp 8x/4x (4 gig up and down data transfer), microsoft open gl overlay planes, 2 sided lightning, hardware 3d window clipping, advanced scene anti antialiasing, dvi output, unified driver uotput (UDI), and more..
    It's designed for 3-d, cad, graphics, designing etc...
    Here's a link:
    http://www.pny.com/products/quadro/fx/540PciExV.asp
    I was wondering only because it cost me $239 from a buddy at his comp. shop.
  16. bullcrew
    bullcrew Member
    153
    I opened a photoshop file (picture) today, 24mb before and increased image to 40k pixels (5.4gig) then rendered it. As fast as I could click it was done with the function. It took 4 seconds for it to increase to this size and ZERO gliching from the computer as I moved and altered it. All this was done with flexi sign pro open in the background and 3 files open for load bearing.
    I brought flexi to the front and altered the files there and NO GLICHING or lag time.
    I love this card, memory help's too!
  17. bullcrew
    bullcrew Member
    153
    Here's a blurb about it: Thoughts and comments are appreciated as I haven't built a computer in a long while.
    NVIDIA QUADRO FX WORKSTATION GPU
    Full 128-bit floating-point precision pipeline
    12-bit subpixel precision
    8 pixels per clock rendering engine
    Hardware accelerated antialiased points and lines
    Hardware OpenGL overlay planes
    Hardware accelerated two-sided lighting
    Hardware accelerated clipping planes
    3rd-generation occlusion culling
    16 textures per pixel
    Hardware-Accelerated Pixel Read-Back
    NEXT GENERATION SHADING ARCHITECTURE
    Fully programmable GPU (OpenGL 1.5/DirectX 9.0 class)
    Long fragment and vertex programs (up to 65,536 instructions)
    Looping and subroutines (up to 256 loops per vertex program)
    Dynamic flow control
    Conditional execution
    HIGH-LEVEL SHADER LANGUAGES
    Optimized compilers for Cg, OpenGL shading language, and Microsoft HLSL
    OpenGL 1.5 and DirectX 9.0 support
    Open source compiler
    ARCHITECTURE
    x16 PCI-Express
    128MB high-speed DDR frame buffer
    128-bit IEEE floating-point precision graphics pipeline
    128-bit color
    32-bit floating point frame buffer
    PACKAGE CONTAINS
    NVIDIA Quadro FX 540 PCI Express graphics board
    PNY Technologies HDTV Video Breakout box
    DVI to VGA Adapter
    CD-ROM Containing:
    Drivers for Windows XP, 2000 & NT including DirectX 9.0 and OpenGL 1.5 support
    Detailed Installation Guide
    Quickstart Installation Guide
    MINIMUM SYSTEM REQUIREMENTS
    PC compatible with Intel Pentium® 4/Xeon® or AMD Athlon®/Opteron® class
    processor or higher
    PCI Express x16 lane bus
    Microsoft Windows® XP, 2000, NT4.0, (Service Pack 6) or Linux®
    128MB system memory
    50MB of available disk space for full installation
    CD-ROM or DVD-ROM drive
    VGA or DVI-I compatible monitor
    350W Power Supply
  18. Cadmn
    2,859
    awesome bullcrew only thing I see & its just preference not AMD
