Trying to find a Small Laminator
Discussion in 'Laminators' started by Jonathan24212, Jun 20, 2020.
  1. Jonathan24212
    Jonathan24212 New Member
    8
    1
    3
    Jun 12, 2020
    Usa
    Hi Guys :)
    I have a 54" printer but we do heat transfer material so we usually cut the material off at max 30" otherwise weeding the excess becomes too difficult.
    I'm trying to find a cold press laminator that will put the medium tack poly transfer mask on and apply even pressure (rather than doing it by hand).
    So I'm looking for a suggestion on a direct-drive (not pneumatic) with a take up reel (since there is a paper backing to the transfer mask) that would work well for heat transfer vinyl.
    I know I can buy one of the very expensive (5k+) but I'd rather not spend that much money... ;)
    Thanks guys!!!
  2. Mixedmedia
    Mixedmedia New Member
    5
    Jan 15, 2015
    Middlesex, NJ
    I have an older 54” Royal Sovereign that we just upgrade to a 63” GFP. Looking for $1000 or B/O was gonna list it this week. Contact me if you’re interested.
  3. iPrintStuff
    iPrintStuff Prints stuff
    949
    255
    63
    Sep 3, 2018
    United Kingdom
    I can’t remember who but I’ve seen a member on this forum with what I think he called a “china laminator”, which was literally just a manual laminator. Probably worth just looking for manual laminators and seeing how you get on.
    That or if you’re pretty handy, it should be fairly easy to make one yourself with some old tubes and a bit ingenuity!
  4. Notarealsignguy
    Notarealsignguy Active Member
    950
    244
    43
    Feb 20, 2020
    Florida
  5. Notarealsignguy
    950
    244
    43
    Feb 20, 2020
    Florida
    Double post
  6. Jonathan24212
    8
    1
    3
    Jun 12, 2020
    Usa
    I actually have that one from amazon but here’s my problem.
    I have the pressure on so high that the handle doesn’t turn it and I roll the “top tube” by hand.
    I do that be because If it’s any lighter pressure then the media doesn’t want to release from the backing to the transfer mask. The thing is that it doesn’t always happen but it does sometimes (causing the graphic to rip in places making me reprint parts).
    Is that because the pressure is to high? Even when I do it manually with a squeegee sometimes it will work and sometimes not. I feel like an idiot doing this and not being able to figure it out.
    I was looking for something automatic to make it even pressure and also to increase speed of production
  7. netsol
    netsol Active Member
    741
    102
    43
    Apr 26, 2016
    englishtown, nj
    i would look on ebay for a used daige
    we bought one of the 25" in 2016 but never used it
    we also, between ebay and craigslist, bought a 38" daige, a 55" daige, a 44" seal & a 65" royal sovereign
    we make out very well this way, but i have been repairing equipment for over 45 years
    it sounds like a used daige would suit your needs very well
  8. Jonathan24212
    8
    1
    3
    Jun 12, 2020
    Usa
  9. netsol
    741
    102
    43
    Apr 26, 2016
    englishtown, nj
    those seem pretty nice
    to hedge your bet, i would cover with an extended wrrantybfrom square trade, or
    warrantec. i believe squaretrade will cover any ebay purchase. view it as catastrophic coverage, just in case you end up with a lemon
  10. Notarealsignguy
    950
    244
    43
    Feb 20, 2020
    Florida
    You should be able to apply premask without a laminator. If you do, hit it with a squeegee after dont use excessive pressure with the laminator.
    If you cant peel it off, try adjusting your cut pressure. Other way is to put it tape side down and roll the backing off rather than pull the tape from the backing.
  11. Jester
    Jester Slow is Fast
    103
    18
    18
    Dec 2, 2019
    SoCal
    Are you using a "high tack" masking material? Many HTV don't work well with medium grip mask.
  12. Jonathan24212
    8
    1
    3
    Jun 12, 2020
    Usa
    When I was talking to Stahls' they explicitly said to use the medium mask (same with Roland people) as the high tack wouldn't release when pressing.
    I just bought a bunch of medium. Do you use high tack? Any problems with it?
  13. Jonathan24212
    8
    1
    3
    Jun 12, 2020
    Usa
    What do you mean by roll the backing off?
  14. signdude48
    signdude48 New Member
    3
    Apr 25, 2012
    watertown, ct
    I have a 30 inch laminator I will sell.
  15. Bubba06
    Bubba06 Just Somebody
    418
    122
    43
    Feb 13, 2005
    Manning SC
    Pressure is not your problem. Once you lay the mask on, yes you have to use a lot of pressure with the squeegee, but when pulling the print off the backing you have to literally snatch it off quick.
    Thats the way it's designed. No laminator will help. Sorry to bring the bad news.
  16. karst41
    karst41 Member
    145
    25
    28
    Nov 3, 2010
    Stone Mountain, GA
    Get the older Royal Sov. If the Top roller is not all cut up then that sounds like a no brainer. There is a Youtube video on adjusting the roller.
