Cjackson0314
Welcome to Signs101!
Haha, yea about like every other forum I have ever joined!
Also, you can put a box around it and it doesnt shrink for some reason.
Thats it. For instance, if i am doing a face for aluminum, I will put the registration marks on it. Then, I just put a bigger box around the whole thing. The only bad thing is, i have to use a 30" roll for a 24" face, 24" for an 18" etc.Commando, you said "You can put a box around it and it doesn't shrink for some reason." Can you explain this? Do you mean that you draw a box around your artwork before printing and that makes it print with an accurate length?
horrrrrrrrrrrrrrrrrrrrrrrible advice.You'll also want to have lower grade media on hand for simple sign work and another for flat surfaces such as box trucks. The good wrap vinyl & laminate is overkill for these. Any way to cut cost is a good thing. Also consider a "hood laminate" not sure what the technical term is but it's formulated for horizontal surfaces that bake in the heat. I'm in Florida so that's a must. When quoting jobs ensure you factor in extra time for rivets, removing badges, cleaning surfaces etc. Also a bonus if you have access to a climate controlled well lit dedicated wrap bay. butane trigger heat guns, good quality squeegees, strong magnets to hold the wrap in place .
Just my 2¢
That sounds like a RIP issue rather than a printer issue. Or am I misunderstanding something?Thats it. For instance, if i am doing a face for aluminum, I will put the registration marks on it. Then, I just put a bigger box around the whole thing. The only bad thing is, i have to use a 30" roll for a 24" face, 24" for an 18" etc.
If its just registration marks, it will shrink 50% of the time.
always use cast on ANYTHING on wheels. It isn't over kill. The sun is still the same on box trucks, as it is on regular vehicles.
get latex machines, we have a bunch - for wraps they are the only choice.
Flexi said it was a printer issue. HP said they dont know what to tell me. This is a common problem with these machines. With different RIPs. Onyx, colorgate..That sounds like a RIP issue rather than a printer issue. Or am I misunderstanding something?
