Trying to match vinyl color
Discussion in 'Vinyl' started by showcase 66, Apr 11, 2011.
  1. showcase 66
    showcase 66 Very Active Member
    1,833
    4
    I have a client that gave me a small decal that he wants me to reproduce with the same color. I believe it is Avery 900 vibrant green. I have not used Avery for a long time and from what I can see, no other brand is close to the color. I tried to get him to use Arlon Spring Green because I have a ton of it. but he wants the same exact color but he said he wanted to make sure it was the lime green on both sides. So when you look out a window it is green not white.
    From what I see the Avery 900 vibrant green is the only exact match to his decal and it has a white backing to it.
    Anyone have any ideas of another vinyl to match this color?
    A close match I think is GMI Lime green. Never used GMI. Any input on this vinyl.
  2. "Deposit Please"
    "Deposit Please" Active Member
    780
    Sep 17, 2009
    Illinois
    FDC has a vibrant green. Also arlon has a bright green called kiwi. These are cast films tho and not sure about backing. they are very very close ...worth to look at.
  3. Drip Dry
    Drip Dry Very Active Member
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    Are you sure the Avery has a white background... I've always thought that Avery was the same color on both sides. I admit that I don't use 900
    Maybe you should check again
  4. signcrafters london
    signcrafters london Very Active Member
    1,186
    5
    38
    May 22, 2010
    London KY
    I don't use Avery anymore, but apparently there are a number of different kinds of 900 series vinyls. Some of them have clear adhesive only. Some of them are available with white, gray or clear adhesive.
    You can look at the spec sheets here --->http://www.na.averygraphics.com/AvGrNA_900UC.asp
  5. showcase 66
    1,833
    4
    The only Avery Chart I have has the same color green with a white backing. It is an older color chart so things may have changed.
    Thanks for the help guys.
  6. Malkin
    Malkin Very Active Member
    2,200
    29
    48
    Feb 11, 2009
    Augusta, ME
    Some avery colors do have the white backing, it's like they are basically printed on.
    I had a huge P-I-T-A job where the customer wanted his window lettering to match a provided paint color chip AND show as that color from both sides of the glass. We managed to get it done (printed) but it wasn't very fun.
  7. SignosaurusRex
    SignosaurusRex Major Contributor
    8,636
    552
    113
    Mar 7, 2007
    Washington State
    900 series "Vibrant Green" is an opaque (white base) adhesive because of the light brilliance of the color. I would say that Arlon's KIWI #79 is your only and best option for a tight match with clear adhesive for two-sided visibility.
