trying to send 1 bitmap file of 3 but prod mgr sends all 3 at once?
Discussion in 'Flexi' started by gabagoo, Oct 15, 2020.
  1. gabagoo
    gabagoo Major Contributor
    5,737
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    I have seen this before but can't figure out why I can't send one image at a time? I even tried marquing the pic but it sends all 3. Decided to delete the other 2 and then bring them back later to print.
    What causes this?
  2. Snydo
    Snydo Active Member
    558
    44
    28
    May 1, 2008
    Mid Michigan
    Could be a mask issue, if you right-click anywhere on the image and 'unmask' isn't grayed out then that is likely the culprit.
  3. IsItFasst
    IsItFasst Member
    375
    12
    18
    Jan 16, 2008
    USA
    If you are using version 19 I think you are describing the issue I had a few times. I was just selecting one item on the screen but was sending all the items on the screen PM even though they weren't selected. Seemed like a glitch as I could close the program, reopen and it would fix itself. Haven't seen that issue in a while but was happening weekly a few months ago.
  4. Bubba06
    Bubba06 Just Somebody
    434
    126
    43
    Feb 13, 2005
    Manning SC
    Make sure to click this button before you send to PM
    • Like Like x 1
  5. IsItFasst
    IsItFasst Member
    375
    12
    18
    Jan 16, 2008
    USA
    That's awesome Bubba06! Never have I had to use that before in the 19 years of using Flexi. Oddly just went to test and had the same problem the OP was describing for the first time in like a month. Your suggestion fixed the issue.
