Stickerman
TLDR: Need printer for vibrant cartoon stickers, 1000 a week, printed on 100mic self adhesive roll, printer needs to be okay if left for couple of weeks at a time, would prefer ink to be water resistant/scratch resistant but can laminate if necessary, budget is up to £11,000, but would preferably like to be in the £7000 range for a printer and plotter, I currently don't laminate but I wouldn't mind if its a vibrant inkjet and then I laminate it for protection and outdoor use to stop fading.
I'm currently using a Mimaki UJV 100-160 printer for stickers at work, which are nice and bright although the tiny detail is lacking a bit. As i'm moving away, I want to continue printing stickers at home for online sales.
I'm currently selling around 300 individual stickers a week (not laminated), with an aim to increase this up to a few thousand per week in the next few years. The stickers are vibrantly coloured, cartoon designs, around 3 inches/76.2mm in size each, with fine design.
The printers ink would ideally be waterproof/water resistant, scratch resistant, rated for outdoor use, although i'm not adverse to using an inkjet printer and laminating.
Currently printing on 100mic self adhesive 30m roll, at 1200x1200 resolution (max), and using a Mimaki FX Plus II plotter cutter for kiss cutting, but I've been looking at getting a Graphtec for die cut and kiss cut stickers. The UV ink has not been very suitable for die cut stickers when they are bleed cut as the UV ink thickness varies, or at least that's been my experience. I've heard better thinks about Graphtec for die cutting, from the Mimaki engineer himself.
Roland BN20 for £5000, but concerns with regards to print speed, fumes, outgassing etc didn't sit right with me as it would be in an inside room at home that I would be in for long periods of time.
I was also advised that I couldn't leave it unattended for a two weeks, as the print heads will clog and not only would I void warranty for negligence it would cost £2500 to fix.
It's likely that I would be having a holiday or two per year, so the printer would need to be left unattended for a a couple of weeks at a time.
HP Latex 315, which is £11,000 because I was advised they're great for stickers, I could move into car wraps and other products, it doesn't smell - no odour, and they can be left alone for a while and the printheads are changeable, the ink won't dry out in the tubes. However it's a bit expensive for a home production. Maybe i'm just being hesitant on spending so much money on it.
Epson Surecolour SC-9500 is around £4750, and the print resolution is 2400x1200, but i'm unsure of the sticker quality in regards to how vivid the colours would be in comparison to the Mimaki UJV 100-160, or if the 100mic self adhesive roll would be suitable, I wouldn't want to change the media if possible.
I'm genuinely quite stuck, if anyone can recommend any prints that would be great. I was also wondering does anyone know of a UK company that I can request samples from for some different printers to see the quality? I don't even mind driving for a day there to see them all. Thanks for any help.
