So I had some time to try and troubleshoot and get the info
APCInk and
Dasdesignguy were asking about.
I did the Carriage Maintenance and shutoff the machine and watched took note of the head. First I wiped the head slowly with a new rubber wiper so that it was clean. After about 30 secs I started noticing white ink starting to come out the head on the right side. After about 10 mins, it had a good bit develop and you can see in the pic below. I would think the right side if Channel 8 (white) but I'm having problems with Channel 7 (white). Not sure if this makes sense to me. After about 10 minutes, I wiped the head again but this time it did not form anymore ink on the head.
I also checked Negative and Positive Pressures. Negative was in range at -2.80. Positive was high at around ~23.20. I was able to get it back down to ~18.60 which I believe is within spec. I have had to adjust the positive pressure a few times in the past. Also the valve for the positive pressure is very sensitive. Sometimes just touching the dial throws it out of spec and just a slight turn makes the pressure go way up or down. It takes a bit of time to get it within the spec range. Not sure if this is normal or if this is part of the problem.
APCInk If it is one of these things, should I replace?
1. Subtank not seated properly (Subtank was replaced when I started having this problem as well as the head so I think I can rule out the Subtank)
2. Air-solenoid-Valve has a leak (I'm not sure where this is located. Is it under the ink bottles when the back is off? Should I replace this? Do you have a part number?)
3. Hole in air lines or poor seal at fittings (Can you let me know where these are located and if I should just replace them? Part numbers would be helpful)
Also Air Purge has been done multiple times on Head 2. We have replaced the head, subtank and even the channel 7 tubing that runs from the ink bottle to the head. Thanks!
Here are the images of the head and Negative/Positive pressure readings
