Goatshaver
Been trying to experiment with layered printing and I wanted to try a print with white and clear. However it cannot print white and clear in the same pass so it has to retract the print (after printing white & 4 color) and then do the clear.
What's happening is the original print is fine then it pulls back to origin when it starts to print the vinyl gets bunched up in front of the rollers on the left hand side. (it lifts the middle sets of rollers for the pull back.) I can't seem to figure out why this is happening.
My only thought is when the print gets to a certain point there is tension on the media roll again and because it's only using the outer rollers one side my be slightly loose and the other side has tension to the roll and when it goes to advance the print it skews and gets bunched up. Not rally sure. I've tried it 3x and the same exact thing happens on the same side every time I've tried it.
Hopefully someone has done this and can lend me some tips on how to get this to work correctly.
