Ugh !!!!
Discussion in 'Flexi' started by yody2, Apr 17, 2008.
  1. yody2
    yody2 New Member
    11
    Hello...
    I am getting so frustrated...
    Can somebody help? I am trying to take an already made image (wheather it be jpg or ??? ) and import it into FLEXI Starter 8 and be able to print it... I've tried using Photoshop & Corel and NOTHING is working so far...
    Trying to learn this to get my business going and Im about ready to give up...
    what am I not doind or doing wrong ???? :help:
  2. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Flexi Starter has rip and print?
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,571
    426
    83
    Sep 11, 2003
    Olympia, WA
    Flexi Starter is little more than a bridge program for cutting vectors. You need to have FlexiSign Pro for printing. What kind of printer are you trying to print to?
  4. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Yup... like has been said. Flexi Starter shouldn't have a rip & print option in it, you have to have Flexi Pro.
  5. DOGraphics
    DOGraphics Very Active Member
    2,351
    2
    :Welcome: 2 :signs101:
  6. ::ONEBADBUG::
    ::ONEBADBUG:: Member
    61
    Yup Flexi starter is cut only!
    the print features are locked in it. You don't get that luxury until you shell out a couple grand to Scanvec for Fsign-pro or Fsign-expert.
    Just curious as to why you can't print from Coreldraw though... Me thinks maybe you have the print software/drivers/profiles not properly installed on the PC you are trying to print from maybe. ...or another problem.
    I assume that if you're cutter is working and that possibly has checked itself as the deafult source printing device maybe and you just need to check that back to the actual printer... at least thats whee I would start anyway.
    Try and print direct from windows pic and fax viewer... If that fails then something is askew and time to begin troubleshooting the printers installation.
  7. yody2
    yody2 New Member
    11
    OK...
    I am evidently too new...
    SORRY !!!
    what exactly is the rip & print ????
    HOW do I do this ???
  8. Fred Weiss
    20,571
    426
    83
    Sep 11, 2003
    Olympia, WA
    Again I ask you: What kind of printer are you trying to print to?
  9. yody2
    yody2 New Member
    11
    Sorry...
    I have the epson 1400 at the moment, trying to start small
    but how do I get something from corel to import into flexi to be able to cut it... ????
  10. DOGraphics
    2,351
    2
    ANSWER THE MAN or you will be BEATTIN TO WITH IN AN INCH OF YOUR LIFE
    j/k :beer
  11. Mike Paul
    5,438
    8
    38
    Dec 30, 2003
    NJ
    I thought you wanted to print it?
  12. yody2
    yody2 New Member
    11
    I want to do that to !!!!
    I cant get it to work either way...
    I have a pic that is a jpg that I want to print to be able to transfer to shirts & import into my flexi progam to cut & it just isnt working either way
  13. Mike Paul
    5,438
    8
    38
    Dec 30, 2003
    NJ
    You can't print it from PS or Corel? Did you install the Epson driver?
  14. yody2
    yody2 New Member
    11
    Yes the driver is installed - I just double checked...
  15. Mike Paul
    5,438
    8
    38
    Dec 30, 2003
    NJ
    You can't import a bitmap, apply a vector contour/cut path to it and output it from your version of Flexi. You need to upgrade your software.
  16. yody2
    yody2 New Member
    11
    That's what I was so afraid of....
    Thank you for all your help !!!!
  17. Cadmn
    Cadmn Very Active Member
    2,859
    you need to learn the difference between vectors(cut)&rastors(print) starting small is fine but you have alot to learn & it ain't easy. before throwing Money at the situation you might want to go work for a sign company & actually learn what you truly need to do this business, sorry all you retailers out there pushing your software & equip telling everyone all ya got to do is push this button & get rich.
