uh oh!
Discussion in 'General Signmaking Topics' started by wes70, Feb 26, 2011.
  1. James Burke
    James Burke Being a grandpa is more fun than working
    3,431
    459
    83
    Jan 2, 2010
    Mitten State
    Whutta mess!
    Perhaps he was looking for some built-in obsolescence...kinda like billboards. At the end of 30 to 60 days, they really begin to look ratty....just about the time when the contract expires.
  2. Joe Diaz
    Joe Diaz Very Active Member
    You know it kind of looks like someone forgot to remove the protective film on the substrate.
  3. Rollie
    Rollie Very Active Member
    1,651
    Dec 20, 2007
    Ontario Canada
  4. WildWestDesigns
    WildWestDesigns Major Contributor
    6,534
    322
    83
    Sep 27, 2010
    Mid TN
    I go up there all the time for weekend trips. I would be pissed to if that company did my signs.
  5. fmg
    fmg Very Active Member
    1,466
    The return of Avery.
  6. RJ California
    RJ California Active Member
    984
    Jul 19, 2005
    California
    Geez, a company gets a $1.4 million contract and uses MacTac?
  7. Sticky Signs
    Sticky Signs Very Active Member
    1,154
    Nov 9, 2009
    Vancouver
    Why the hell would they print on clear? In fact, hardly looks like printing would be the way to go for such simple signs. Oh well, better them than me.
  8. cgsigns_jamie
    cgsigns_jamie Very Active Member
    Looks like the panels are reflective (?)... probably used clear so the light would still reflect... but like RJ said.. why MacTac?
  9. CheapVehicleWrap
    CheapVehicleWrap Very Active Member
    3,943
    1
    Butch Hackery.
  10. binki
    binki Premium Subscriber
    1,542
    40
    48
    Jul 23, 2007
    The PRC
    where does one find a 1.5 million dollar contract to put vinyl over coro?
  11. Rick
    Rick Certified Enneadecagon Designer
    6,955
    389
    83
    Apr 17, 2003
    Valle Vista
    The company who made the signs is a pretty good sign company, the website is worth checking out. The design company is also pretty good, they are worth checking out too.
    I would like to get my mits on the bid documents, the RFQ and the construction documents. I tried looking for the bid docs as they are usually posted online. All I found was an old pdf with bad callouts asking for engineer grade, these signs require retroreflective.
    The sign package is way more than directional signs, they also have some large size monument structures and directories. I think the 250k held back from the sign company is only the portion the sign company is being blamed for.
    You have to bid as they are designed, if you do not build to the specs for any reason, you have to request changes prior to bidding is done so everyone bids on the same thing. The client technically can not ask for a major specification change either as that can come under scrutiny from competitive companies.
    I'm thinking a bad spec got into the bid documents, someone in the middle changed it due to costs, or a sub contractor cheaped out. After reading the clients idea that the designer and sign company knew more is a cop out. On jobs like this I have volumes of emails printed out in folders and also respond to phone calls with a return email summarizing the discussion to make sure it's documented because of crap like this.
    All the city signs I have done are screen printed with 3M Translucent inks (yep, on panels that big) or their cut film since the whole panel is required to be reflective, those panels I have seen for this job are a bit too opaque.
  12. Joe Diaz
    Like someone else pointed out, that is reflective... actually that is high intensity reflective. They want the reflective to shine through. We did our wayfinding signs here in town and did the same thing, but with better products apparently (or we remembered to take the protective film off of the sign blanks :Big Laugh) Those signs are about 3 years old now, and they are doing just fine. We need to replace them but not because the sign is falling apart, but because all of them are getting new information on them.
    But I agree with you, why on such a simple sign? In our case the design called for a print (multiple colors, a few gradients), in there case it looks like it was just a flat color. Now if you are making signs with high intensity for the interstate, in our neck of the woods, there are specific requirements. One of them specifically states that the graphics not be printed on clear. My guess is that has more to do with the longevity of the ink then the material.
    Mactac or not, You rarely see vinyl peeling off on it's own like that a week after being installed. (not even Avery) It is coming off so clean, the only thing I've ever seen do that is the protective film you get on your sign blanks. But then again I wasn't there and I'm basing my opinion off of a few photos and a press release.
  13. bob
    bob Major Contributor
    5,273
    306
    83
    Nov 4, 2005
    earth
    The available evidence would indicate that to be be the case. The black on the backside of the peeling image as well as just how it is peeling [in a rather un-vinyl like manner] would seem to confirm this.
  14. Sticky Signs
    1,154
    Nov 9, 2009
    Vancouver
    Ooops my bad. Didn't realize it was reflective. I take it all back!
