UJF-3042HG Gloss Help
imrtstc
I am having issues when i use gloss on my 3042HG. It looks like banding when finished. Cleaned heads hard and wiped undercarriage. still an issue. Anybody got a solution?
artbot
do you have the lamps set up for a "post cure" or are they curing the thread/pass as soon as it's laid down?
artbot
on my printer there is a utility that has arrows and little light bulbs and you choose the option. the varnish needs time to wet out in order to become glossy. so whatever your printer offers, you'll be wanting the ink to be laid down, the lamp would be off trailing/behind the head or in effect the lamp is on ahead of the head direction. this means that the lamp is curing "coming back" not immediately after the ink is laid down. there may even be a "cure between passes" built into your firmware. but that is the general concept.
imrtstc
Ok, i tried the 5-3-1 and in my UV mode i have print and irridation. The piece looks great when the clear is laid down, but after the light hits it it is banded. Everything gets cleaned daily. I am stumped.
