Question Unable to load cartridge into machine
Dennis Schaub
I have had my Edge FX for around 10 years. The cartridges have never loaded as easy I felt they should, usually have to jam them in with a fair amount of force. The flapper door also get caught on the side, like something isn't aligning properly. Today, the top doesn't seem to be lifting all the way and making loading the cartridges nearly impossible. After some googling, I decided I should grease the z-axis motor, but that didnt seem to help. Also went into diagnostics and attempted to increase the raise height, but I believe it was maxed out. Any other suggestions?
Thank You!
netsol
not to state the obvious, but repeated "jamming" of the cartridge has bent something
with laser printers, i normally use a cartridge with the retracting door removed, to be able to see what moves on insertion so i can tweak it
FunkotronXL
Start by checking your cartridges for wear-and-tear. If the delta/triangle shape on top of the cartridge at the corners is looking like it's been scraped off, should consider replacing it. Just a common red flag from years of working with these printers.
The more worn the cartridge is, the more it won't seat properly into the loading mechanism. Creates the potential for additional hardware failures due to excess resistance on the z-axis travel.
Gerber and suppliers consider the FX foil carriers as a "consumable" for this reason and recommending periodically replacing them.
