Hey ya'll
We had a power surge over the weekend, and now both of our roland printers are unable to connect to versaworks.Just focusing on the primary printer at the moment. On the PC, in IP config, the IP address is set to 192.168.0.1. However in network connection details, DHCP is enabled and the auto auto config IP is totally different (169.254.142.185) Those are supposed to match right? I un-enabled dhcp, copied the IP and Gateway from IP config, and then reset the IP addr in the printer to 192.168.0.001. Then I go into versaworks, and give it the IP 192.168.0.001 Hitting the VERIFY button brings up a message that says "device not found or status not acquired correctly from the device." And that's where I'm stuck. any insights would be much appreciated. Thanks!
