For folks that have worked on unclogging dx4's. Can I use warm/hot distilled water? If using an ultrasonic, would you use solvent cleaner or distilled water? An ultrasonic holds a lot of liquid. Also, I have fluid coming out the sides of the metal bracket that holds the teflon plate in place. Does that mean the bracket is not tight enough?
