I imagine down in Florida, you might not need heating at all. What's the coldest it's gonna get and what's the warmest you expect ?? Coldest would be 30 degrees and warmest would be 98 degrees. How much humidity do you anticipate ?? Average humidity will be 60% with some days in the summer at 92% If you don't have a climate controlled area, it's not the end of the world, but we need to know more than something is unconditioned. That merely means you have walls, windows and a roof.
Is this in a garage ?? Yes
Is this in a house ??
Is this in a warehouse ??
Is this in a shop somewhere ??
Is it carpeted ?? Not currently but could be, currently concrete
Are the walls/roof insulated ?? Yes, R30 roof and R19 walls
Do you have adequate ventilation ?? Yes, it will be well ventilated as it has a garage door that can be opened.
Believe it or not, these items will help us help you. Your real estate can help tremendously by building another barrier of enclosed area or any number of things.
If this is just a garage, put a window unit in it and you'll take care of 2/3 of your problems. The nights it hits 30º, let it warm up the next day before using. Rugs add static, so just paint the floor to keep dust bunnies from forming.
You don't wanna use a garage door for ventilation, you'll let bugs, dirt, birds and all kinds of other contaminants in which will be harmful to your prints. Knock a hole in the wall and put a strong exhaust unit in it.
Let's put it this way.....
You're a student, not doing this full time and you say you have ZERO experience, so this is not your livelihood. Things will take getting used to, but if you are doing this as a hobby and just wanna know how to protect your investment, how can we take you serious, if you wanna stick it, in a garage ?? There's a myriad of things you should do, but it doesn't appear you will do any of them, like build a climate controlled room, knock holes in the walls or put in filtration systems. You haven't mentioned how large/small this garage is. Is it connected to the house ?? Do you have room for a laminator, work benches and a computer station ??
If you were actually starting a business, you'd be putting a business plan together and that would include the necessities to help your environment. You always wanna preserve or secure your core interests, but you need to heed good advice and put your eyes back in their sockets. Think this thing through, before you go off willie-nillie and not have everything you need and just wing it..... or there will be a printer for sale come this spring from Florida
I have no idea what you are talking about. I asked what I thought was a simple question, "Is anyone using his/her printer in an unconditioned space and if so, how do you overcome the related issues?" and somehow the question has morphed in to a discussion about business plans and not taking my question seriously.
I understand the best way to start a business and the best way to set up a shop. I wanted to simply know what time it is, not how to build a watch.
The humidity in summer will be a pain. I weed and mask in the A/C but I laminate in my shop which doesnt have a/c. In my experience, the laminate backing paper gets wrinkled on the loose end but once a its unrolled a little its fine. The vinyl has a tendency to do the same (not quite as bad) when we have it laid out to install if its really humid like after a rain storm. Its probably possible but not ideal and without knowing anything on your situation Id venture to say that your area will be difficult to control dust which will be a bigger problem. If you do it, Id recommend unloading the printer and rolling the vinyl tight after each run so the liner's not as exposed to the air for a lot of time. Swelled up media will end up causing head strikes.
The dirt and dust getting tracked in is what I would be concerned about. Be careful when sweeping and blowing air around. We have a coating of dust on our production machine after only a day or two of sitting. I wipe down all the surfaces the carriage...(and more importantly) the printheads will move over. I do this before even turning the machine on. I also cover the machine with a drop cloth if I am doing anything that will move dust around.
We print on dye sub paper in Seattle...humidity is a nightmare, since the paper is made to sponge our aqueous ink. I had all sorts of problems until I started wrapping my paper in cling wrap. I mean within minutes of printing. If you control your process, and your materials...an uncontrolled environment is doable.
I've been printing for 20 years, and am the "manager" at my shop...but I clean clean clean. The more often I do it, the less problems are apt to occur.
Another key is to have ink flow through the machine...every day. You're not saving yourself money by saving ink...in the process you'll destroy your printheads.
It's like a car...it wants to run, the more it sits, the worse off you are.
Good luck!
