Yes, it is the wiper position sensor, it tells the printer when the wipers have moved and gone back into the correct position. If this is faulty the printer wont initialise properly. I have the sensors in stock if you need oneThe cover is broken
This sensor is behind the cleaning section
Thank youYes, it is the wiper position sensor, it tells the printer when the wipers have moved and gone back into the correct position. If this is faulty the printer wont initialise properly. I have the sensors in stock if you need one
It connects to the right hand side of the cleaning station as you look at it from the front, towards the back. You should see a hole where the sensor diodes part fits throughThank you
Do you know exactly where it will be installed?
It is just to the side of where the wipers come out from their coverDo you mean the station that the cap top is connected to? Or the part where wiper Head is there?
Because these two parts are separate
You're welcomeTHANKS A MILLION
I REALLY APPRECIATE IT
