USB long length connection
Discussion in 'General Signmaking Topics' started by Pinfinity, Sep 30, 2010.
  1. Pinfinity
    Pinfinity Active Member
    644
    1
    18
    Apr 8, 2010
    NJ
    I'm hoping someone can help me with this. I would like to hook up a newly purchased digital printer and cutter to my pc which is approximately 25' away in an adjacent room.
    They require USB connections obviously. Is there a problem with a USBV cables that length, or what would be the best way to hook these two units up without problems?
    Thanks for any suggestions
  2. randya
    randya Very Active Member
    2,060
    3
    38
    Apr 6, 2007
    Arizona
    In reality you probably want to hook your printer up with an IP cable.
    For the cutter, IF it actually sends USB data, you should be able to use a USB repeater.
    I know that the Mutoh cutters use a USB cable but not USB code, so a repeater will not work on that, and the cutter needs to be closer to the PC.
  3. Stealth Ryder
    Stealth Ryder Very Active Member
    1,722
    Jul 16, 2009
    Texas
    Call your dealers Tech Support and let them help you with initial set-up!!!
    The printer connects via TCP/IP and the cutter uses a USB Cable in most cases, you can use a com cable if needed.
  4. Pinfinity
    644
    1
    18
    Apr 8, 2010
    NJ
    Thank you Randya, the cutter is a q54 vinyl express cutter, and the printer is a Mutoh vj 48. I am not familiar with a repeater. Is it like a splice connection?
    Also, you say Mutoh does not use USB code, does that apply to the printer as well?
  5. Stealth Ryder
    1,722
    Jul 16, 2009
    Texas
    Your Printer should be connected with the 25" Ethernet Cable that was provided.
    Your cutter should be connected with the USB Cable that was provided.
    USB Cables should not exceed 12' (recommended) for proper communications.
    You paid for Technical Support with the purchase of your equipment, I suggest you utilize it...
  6. petesign
    petesign Very Active Member
    1,191
    1
    38
    Feb 27, 2010
    Hoover AL
    I had the same problem, and there is a workaround. You have to get a powered USB hub, and connect two 12' USB cables with it. The hardest part you will have is finding the right cables and the right hub so it all fits together.
    I have experienced no issues running two usb cables this way, but it has to be a powered hub, not just something to link the two cables together.
    Hope that helps you out.
  7. gbarker
    gbarker Member
    203
    Another easy option is to use a USB to ethernet adapter set. They are available on the internet and allowed me to use my plotter 30' away from my computer.
  8. laserman70
    laserman70 Very Active Member
    1,269
    1
    38
    Dec 25, 2007
    usa
    They make usb booster cables. We have our cutter on 2 usb booster cables. Google it you will find them.
    Good luck
  9. randya
    2,060
    3
    38
    Apr 6, 2007
    Arizona
    I am with Stealth Ryder,
    The technical support that comes with your purchase of Printer and Cutter can be invaluable to someone new to printing/cutting.
    These guys sell and service a LOT of this equipment, and can save you hours and literally thousands of dollars in wasted time and materials, to get you up to speed faster and more efficiently.
  10. oldgoatroper
    oldgoatroper Roper of Goats. Old ones.
    1,753
    109
    63
    Jul 28, 2009
    Alberta
    Powered hub is the way to go. Along with that get two 12' (or longer if you can) USB cables with Type A / Type B ends and connnect everything up.
