Using a VersaCamm 540 as a cutter from signlab.
I've gotten it to cut but when I send a larger job it just stops part way through because it's not using the signlab spooler. Any suggestions?
Thanks,
T
Blizare
Use illustrator. Load the cutting driver from the versawerks disc and you can cut from there no problem
