Using Reverse Wound On A Seal 62 Ultra
Discussion in 'Miscellaneous Hardware' started by quikseps, Jul 7, 2007.
  1. quikseps
    quikseps Member
    151
    Buying a Seal 62 Ultra laminator and was wondering if there's any issues using reverse wound laminate on this unit such as Oracal? The company itself could not give me a straight answer.
  2. chopper
    chopper Very Active Member
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    I have a seal image plus 62 and I use oracal laminate all the time,
    290, and 210, laminate with out issue, infact it works great I am not familiar with the ultra, but if you are using the cold laminate there shouldnt be a problem. all you would need to do is flip the roll when you load it depending on which way it is wound//chopper
  3. quikseps
    quikseps Member
    151
    Thanks....I thought it wouldn't be an issue but wanted to hear from someone with a Seal. One would think the tech at the company itself could answer this question.
