Need Help Uv ink easily peeled off.
sethkyejo
Tonyrich Arts
I have a Flatbed UVprinter 9060. Thr can be easily peeled off. It is a disappointment we keep rejecting customer. Pls help how to fix this.
Christian @ 2CT Media
You need a lot more info to get good answers, but I would say that you need to focus on the curing. I don't think you have enough dwell time until full cure is achieved. This is causing the ink to cure to itself but not fully bite in to the surface.
Andy D
Is it peeling up on several different substrates?
If so, most times I have had UV ink peel right up, it has been a UV light issue and/or
too much ink problem. Like paint, if you put too much on, the bottom layer doesn't cure correctly.
You might also need to try increasing or replacing the UV lights.
What I would do is print a light color box on a substrate you have been having issues with.
If it doesn't peel, I would cut a X the ink & put duct tape on it and rip it off... if it still doesn't peel, it's probably your
profile's ink limit.
I agree with everyone here that your lights are the first thing you'll want to check. Also, has your supplier changed the material you're printing on? Some cheaper materials haven't been treated properly to create proper ink adhesion, even if your lights are curing everything okay.
sethkyejo
Tonyrich Arts
Okay. But the ink i have says it is rigid. Means it cant be bent. Does it have anything to do with all these? Its called RIGID UV ink for epson dx5 2019
Andy D
On our Agfa Anapurna, when we bought it, it got set up with Gen1 Ink, which was very brittle and would chip when we cut the substrate.
We paid to switch over to (I think) Gen5, and that was much more flexible and solved 90% of our issues.
I would check and see if your printer manufacturer offers a more flexible ink for your printer.
sethkyejo
Tonyrich Arts
Can i use any uv ink?
Andy D
No, you have to use one that's spec'd for your printer.
There are probably 3rd party inks you can switch to, if you choose, but that can be risky.
We have changed other UV printers over & some ink providers will send a teck to make the change free of charge.
Nazdar offers ink for several types of printers, you can talk to them, but I would rule out the lights and profiles before
I switched inks.
sethkyejo
Tonyrich Arts
Thanks. Let me try.
I switched inks.
