I have been using a Colorspan 72UVX to print directly to corrugated plastic for the past six years without many problems. Corrugated plastic has been the one non-roll material that I can print on consistently without trouble, but now I've run into an interesting problem (that fortunately does not seem wide spread).
We picked up a small corrugated plastic sign from the field last week and nearly half of the sign is blank. The ink hasn't faded - it appears to have fallen off. There are some areas where you can see the ink cracking. You can flake off pieces with your fingernail.
What would cause this problem? The sign I saw earlier today is not a brand new sign, but we have signs in the field significantly older with no problems. The sign was produced this year for sure - I would guess this past May.
Is it possible that extremely hot weather caused the cracking?
On a similar note, last year we began printing directly to Maxmetal (a brand of aluminum composite panel). It has worked out okay, but the UV ink does not seem to stick well to the surface. Fingernails don't always scratch the ink, but it doesn't take much to scratch it - a razor blade will shave it off completely. Does anyone have advice for making the ink adhere better?
