v cut & route lines on the same path
DrunknMonk
Hi im new to cutting on a CNC, looking at making tray signs, is it possible someone can send me a DXF file that shows the different paths/lines you use to make a tray sign, what order you cut them in, is it V cut first, then cut the outside path ? also how do you cut your corners out ? thanks,
