Vaccuum not working?
Discussion in 'Graphtec' started by Sparky, Feb 27, 2008.
  1. Sparky
    Sparky Active Member
    586
    On my FC700 (64") i am getting inconsistent cuts across the cutting plane. Sometimes the depth will be great and then others it is way to deep and goes through the paper, then it will just barely touch the surface - ALL ON THE SAME JOB.
    Is it possible the vacuum is out and the vinyl doesn't get sucked down? That makes sense for the penetrating cuts, but then the cuts that don't quite have the force to get through the vinyl.
    Thanks in advance if you have some advice!
  2. Case
    Case Member
    378
    7
    18
    Jul 21, 2004
    IN
    Firmware version 1.9 addresses this issue on the 64" FC7000(non mk2)... What version of firmware are you at? If you are not at 1.9, you need to get it...If you can't locate it, I can help you with that when I'm in...
    Case
  3. Sparky
    586
    Doh - I am at 1.4!
    I will look now for the upgrade!
  4. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Didn't know the machine had a vacuum....???
  5. Case
    Case Member
    378
    7
    18
    Jul 21, 2004
    IN
    spark, i sent you the link....
    case
  6. ProWraps™
    ProWraps™ Guest
    yup sure does. even my lynx s60 has a vacuum. case, if i have the non mk2 version of the 7000-130 should i worry about upping my firmware?
  7. Case
    Case Member
    378
    7
    18
    Jul 21, 2004
    IN
    what version is the firmware at? I can tell you if it will resolve an issue you may be encountering....
    case
  8. ProWraps™
    ProWraps™ Guest
    ill check it a soon as i get into the shop.. only problems we have so far is that the contour cut is about 1/16" off. and the fact that we have to keep switching from hp-gl to gp-gl to use cutmaster. but thats no biggie. thanks for the help. much appriciated.
  9. Case
    Case Member
    378
    7
    18
    Jul 21, 2004
    IN
    yeah, unfortunately Onyx(cut-server), flexi, omega, etc... communicate with the HPGL language and the cutting master plug-in communicates with the GPGL language... No quick fix there... Your cuts are a 1/16 off huh? Have you tried :
    Setting the AXIS OFFSET ADJUSTMENT (Method 2)??? Look it up in your user's guide on your cd or download it off graphtec's website... you should be able to adjust that cut being off... basically when you do this, you load a sheet of paper in your plotter...(you have the fiber tip marker loaded during this)... you go into the axis offset adjustment.... method 2... it draws a cross mark and then it scans it withe RMS... (it tells you to change pens so you can distinguish where it draws a second cross mark but you don't have to, just makes it easier to see)......then if it is off you can adjust it in the x and y directions... this has solved a lot of peoples issues with their contours being off... look it up in the manual, i may not be explaining it in english very good...lol
    i would also say many times if it's not broke don't fix it, but i recommend going to the latest version of 1.9 firmware on the FC7000 series and going to 3.51 on the FC7000mk2 series.
    case
  10. ProWraps™
    ProWraps™ Guest
    case, i was not aware of that setting. i will do that tomorrow for sure. thanks a ton for the suggestion.
