Hey, Chad, what part of the state are you? You will probably have to do some more soaking to get all of the missing nozzles back after you install the new MS. And, before you run the 1st cleaning cycle, it's a good idea to use a swab and moisten the rubber around the new cap top with cleaning fluid. Doing this helps it to make a good seal on the print head. I bought my 1204 new about 4 years ago. The first thing I did was to remove the right side cover and top cover, permanently. Next, I did away with the waste ink tray and put a bottle beneath the frame for the waste ink to drain into. When I do the once-a-day "short" cleaning, I pull up a chair and watch the waste ink going into the drain bottle. Next, I routed the spit box waste ink to go into the bottle, too. Unless your 1204 is very old, there are holes in the frame under the MS for the waste ink tubing. Once a week I use a syringe to push ink backwards through the waste ink tubes and up into the cap top. Then, I pinch off the wast ink tubes near the end, sop up excess ink in the cap top, park the head, and let it set overnight. I un-pinch it the next morning before I run a cleaning cycle. Every 2 or 3 days, I use a syringe attached to a short piece of pump tubing, and quickly force air through the air tube that is under the cap top. You don't have to remove anything to do this.
