lucasdowden
make sure you put a syringe on both hoses ( or pinch one off) so you aren't just sucking air from the other black hose
I'm located in Greenville. I will message you thanks.Chad, where are you located in MS? I'm halfway between Hattiesburg & Gulfport. If you want to, PM me your phone number.
I will probably replace the CR board anyway but is there a way to check it or the main board? Just would be nice to know if it's messed up before I replace it. I keep replacing parts and get this hopefulness that it's gonna fix it just to be let down again hah. Thanks for your help so far and to everyone else as well.Of what I understand everything with the head goes back to the F2 fuse. Since you check that and it is still in working order, did you replace the head cables when you put the new head in? Working back its the head, head cables, CR board, Cables to the mainboard and then mainboard.
Try unplugging the head cables and checking those both at the head and the CR board, make sure that none of the metal tabs are touching another one, if they look good put them back in and try that.
When I was looking through this site I remember seeing someone having the same problem of no ink coming through the head... they replaced everything and it ended up being the CR board.
I'd recommend getting new head cables and a CR board and go from there...
I will replace the CR board first since it's not very expensive. Don't know if this is correct but I have read that if the main board is messed up then the printer will act crazy and won't operate as normal. As far as operating normal my printer does just that except no ink flow. I have been trying to get a technician on the phone from sign warehouse(where I bought the printer) but they haven't called me back yet.I asked the same question about the mainboard. No way to check the actual board, only the fuse. If the fuse is blown then you know something is shorting out or wrong somewhere.
Well after replacing the dampers there is no change. I am looking at the CR board now just trying to rule everything out. I have found a fuse on the board that I can't get continuity to. I am not sure what this fuse does or if it is a fuse. I am posting some pictures if anyone of you have any idea. Thanks.
Not sure how to post pics here but maybe this will work.
Imgur: The most awesome images on the Internet
