ValueJet 1204 without smart chips
Discussion in 'Mutoh' started by Roland, May 18, 2011.
  1. Roland
    Roland New Member
    23
    Hi all!
    How can I trick a Mutoh ValueJet 1204? I want to use 3rd party inks but I can't do it because of the "smart chips".
    Any hints?
    Thanks in advance!
  2. FatCat
    FatCat Very Active Member
    1,867
    106
    63
    Feb 12, 2007
    Columbus, Ohio
    Seen something a long time ago about having to downgrade your firmware to a really old version and also I think you had to have an older model JV-1204??? Maybe someone on here can clear that up for you.
    *Just curious, what ink are you going to use? Companies like FieldCenter and JetBest USA offer bulk ink by the liter and you can buy blank smartcards for like $5/ea.
  3. Roland
    Roland New Member
    23
    I really hope someone will open my eyes regarding this problem. If blank smartcards are the only solution I have, then ..this is it! But...maybe...what if....
    I will use Nazdar-Lyson products. I heard that are pretty good inks. Opinions?
    Thank you!
  4. NZDR-Payne
    NZDR-Payne Member
    59
    I hear they are pretty good too...but I might be biased.
  5. Gabriel
    Gabriel Member
    275
    That ink is very popular in Romania. I use them and they are just fine!
  6. henryp
    henryp Member
    269
    5
    18
    Sep 25, 2006
    Sydney Australia
    You need to install the modified ink parameter (.ulk file) to the printer to bypass the smart chips.
    • Like Like x 1
  7. OLE
    OLE Member
    45
    Mar 1, 2010
    poodsfp
    Where the.ulk file is located?
    I've never heard about .ulk extension!
  8. Gabriel
    Gabriel Member
    275
    Neither do I!
  9. jbennett
    jbennett Member
    349
    Jun 12, 2003
    Tennessee
    Would be nice if someone could explain some options for alternative or bulk ink for a VJ 1204. I was actually going to ask if there was anything useful that could be done with old empty cartridges. For some reason, I have never been able to make myself throw them away. I have hundreds of them!! I also have a card programmer that may or may not have been used many years ago on sat TV cards :) Appears to have some sort of ISO7816 card on the cartridges.
    jbennett
  10. randya
    randya Very Active Member
    2,060
    3
    38
    Apr 6, 2007
    Arizona
  11. Roland
    Roland New Member
    23
    Can you please tell us more about that .ulk file???
    Thanks a lot!
    Randya, thank you for the link, but I don't understand much on how can I "trick" my Mutoh. Can you please be more specific?
    Regards
  12. henryp
    henryp Member
    269
    5
    18
    Sep 25, 2006
    Sydney Australia
    This is how we do it in Australia, not sure if the same applies to the rest of the world.
    The .ulk file is part of the .mpi file which is embedded on the printer. The .mpi file can be extracted from the printer through the Mutoh Service Assistance (MSA) program. After extraction, the .mpi file is emailed to Mutoh, who from this mpi data, will then create a new .ulk file specific to your printer which will then be emailed back to you. The modified .ulk file is then copied back to the printer, again using MSA program. This process is usually done through the Mutoh dealers as there is a fee involved in unlocking each printer.
  13. OLE
    OLE Member
    45
    Mar 1, 2010
    poodsfp
    Yes, you are right, there are files with .mpi and .ulk extensions, indeed!
    It sounds like legal procedure, but I think it is not available in the whole world.
    How much did you pay for it?
  14. henryp
    henryp Member
    269
    5
    18
    Sep 25, 2006
    Sydney Australia
    Not sure how much, this is done through the dealers. This allows mainly waterbased ink Valuejet printers to run 3rd party inks for printing on film positive, transfer paper or direct to fabric.
  15. premiercolour
    premiercolour A Mutoh, Mimaki dealer for sales and services
    We have excellent compatible eco solvent ink for Mutoh Valuejet. As long as you are using Eco Ultra ink from Mutoh, no flush is required.
  16. Tendai
    Tendai New Member
    8
    Saturday
    United Kingdom
    Please help.
    We have a mutoh valuejet 1304 which is unchiped we have used it for over 2 years now using the bulk ink system without chips. Yesterday it just showing [inks not original] and it won't go past that.
  17. Tendai
    Tendai New Member
    8
    Saturday
    United Kingdom
    Is this done remotely or someone has to come to our machine.
