Boudica
Hi gang. I have another variable data road block. We are making 2,000 numbered decals. I've gotten the artwork set up correctly, and imported the spreadsheet - this worked except for one major thing - the text reads vertically and VW will not format it like that. So, I created a box for each digit in the artwork, and made a new spreadsheet with a VD field for each digit. I thought this would work, but now Versa Works hangs when I try to add the spreadsheet. It did not before. In theory, I should be able to have 20 variable fields - why is a measly 5 hanging the RIP? I'm sure I'm not doing something correct with the spreadsheet.
Any insight would be appreciated
