Wow!!! Much thanks for this superb effort --- I grabbed this as soon as I saw it......well done and thanks for sharing!!!!!!!.............JPHere is one I made a couple years ago. True vector art, not all of the latest colors, but you could add to it.
For those that use this, what does it get you? Are you looking for how your printer will print a particular PMS?
Yes,... and for those eager enough, "theoretically", you should have a printed chart for each type of media and combination of profiles that you typically use on an ongoing basis ------ this could lead to quite a library of archived samples ----JPFor those that use this, what does it get you? Are you looking for how your printer will print a particular PMS?
thats what I used them for.
The problem I see here is that you may not be looking at anything useful.
If it does not match PMS, then what do you do?
I find a CMY mix chart output on my target vinyl to be far more useful. That way I can run a PMS swatch book across until I have a match then the swatch tells me what mix of CMY it is. Plug that back into the vector and done.
How do you accomplish this with a PMS chart?
client: I need my logo to match pantone 356
me (cross reference to printed chart, sets logo at pantone 355)
a bit bass-ackwards, I know
I just want to understand, so please dont take offense.
What of your printed PMS chart does not match your PMS swatchbook?
Then you find the next closest swatch that does, and plug in that number knowing that when it prints, it will be close to your target. I do it all the time.
I submit that this would work, however I believe this (below) chart will help be more precise and keep you from feeding the dumpster:
http://www.summa.be/download/cmy.eps
Do you have a link for this chart in a higher resolution?
This file is only 72dpi (monitor resolution)....
and what of the K ink?
