versa works question
Discussion in 'RIP Software & Color Management' started by crny1, Jan 24, 2019.
  1. crny1
    crny1 Member
    441
    23
    18
    Mar 22, 2015
    IL
    I ahve a file loaded into the queue that is .pdf and it was multiple artboards so therefor versa sees it as 8 pages basically. A installer has damaged a page and needs it reprinted. Is there a way to print just a certain page of the file? In clip and tile I cant grey out any pages. Is this possible or do I need to reload it as just that artboard?
    Thaks
  2. Neil Stimpson
    Neil Stimpson Dirt Industries Graphics
    5
    Jan 8, 2019
    North Carolina
    I don't print in .pdf so this may not be relevant, but I use .eps and when there are multiple artboards I can use the clip and tile to select the printing area I would like to reprint, at the bottom of the clip and tile there is a page select tab as well to use if I remember correctly.
  3. JulieS
    JulieS Member
    89
    10
    8
    Jan 15, 2011
    Columbia, SC
    There's a "page range" button under the Layout tab...that should do it, I think.
  4. crny1
    crny1 Member
    441
    23
    18
    Mar 22, 2015
    IL
    Bingo! Thats it! I knew I was overlooking it somewhere. Thank you.
