Versacamm keeps saying CARTRIDGES DISCONNECTED
inkmed
Do you use original cartridges or compatible cartridges?
This problem always caused by catridge chips.
You can contact your ink supplier about it.
Adam Yang from Inkmed
madsign25
Have this error when starting printer or after press button to make carriage move or after sending job from pc and what model printer you have .
Have you check the trailling cable which connect main board to head carriage are connected well ,remove the top cover check if there any wrinkles on the cable mybe it's make disconnected if have multimeter test it ,on the head carriage the base where the cable connect have little piece like drawer when out you can release cable when connect cable you must make in sure that not broken it's holding the cable and make that contact part on cable touch the contact part on board .
Northern Design
Northern Design Graphics
insert cleaning swab
insert a cleaning swab on the right side of the cartridge when you slide it in to the slot, it applies a little pressure on the cartridge and makes the connection.
I have had this problem for a year
