VersaCamm Owners / Users ...
Discussion in 'Roland' started by Chad., Feb 5, 2007.
  1. Chad.
    Chad. Active Member
    659
    1
    Do you use the sheet cut function on banner material ?
  2. Spud
    Spud Active Member
    524
    No.. lift up the wheels, roll it out a bit, lock back the wheels that cut off the banner material using a larger box cutter knife..
  3. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    I do, and have for many, many banners.
  4. Chad.
    Chad. Active Member
    659
    1
    Thats what i have been doing ... just making sure i was not the only person doing so ... i dont lift up the wheels though, i just hold the forward arrow.
  5. 2NinerNiner2
    2NinerNiner2 Very Active Member
    1,122
    Mar 21, 2006
    Calgary, AB
    Same here ... feed and sheet-cut :)
  6. mystysue
    mystysue Active Member
    999
    5
    38
    Mar 14, 2006
    I use the sheet cutter.. always have with it.. i do make sure that i am holding down the side that is to my left when im facing the machine, The tech support guy that installed my machine recommended that just to make sure that edge is laying flat.
    But i have had no problems cutting banners with the sheet cutter.
  7. Gino
    Gino Premium Subscriber
    33,129
    2,262
    113
    Jun 7, 2006
    PA
    We sheet cut it all.
  8. Doyle
    Doyle Very Active Member
    2,533
    4
    38
    Dec 4, 2006
    Michigan
    Same here, you know that blade is a consumable part on the versacamm, and a new one is like $5. Mine has cut just fine for almost 2 years now, and I sheet cut banners, perforated film, etc. Though I do not think that I would want to try it on magnetic.
  9. GregT
    GregT Very Active Member
    I sheet cut everything we run thru the 300V
  10. ChiknNutz
    4,789
    2
    I have a pile of blades that came with mine, and have only replaced them a couple of times so far. Still, they are a CHEAP consumable and I've had no ill effects in using the Sheet Cut function for banners.
  11. graphicnature
    graphicnature Member
    117
    i do it seems to work fine to me
  12. threeputt
    threeputt Very Active Member
    3,389
    1
    38
    Mar 10, 2006
    washington state
    My Roland's a year old, runs everyday. We use the sheet cut feature with everything we print. Just changed the blade for the first time in about a year the other day. Still have some from the original packet.
    They're not expensive and last a long time.
  13. Spud
    Spud Active Member
    524
    Really? That's crazy - every time we sheet cut banner material it pulls the blade out of the magnetic - any advice?
  14. Gino
    33,129
    2,262
    113
    Jun 7, 2006
    PA
    Epoxy.
  15. Former member
    Former member Member
    484
    1
    I sheet cut EVERYTHING.
  16. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    You arn't using the sheet cut off function with the long media clamps in place are you? Can't do that, gotta remove them first. On my Versacamm I use the sheet cut off function on banner material without any problems.
  17. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    OH' SHEET - Cut Everything ! ! !
  18. player
    player Major Contributor
    4,909
    186
    63
    Apr 24, 2006
    Toronto
    Apparently changing the blade frequently can prevent little pieces of frayed "cut-off" material from clogging the works.
    P
  19. Replicator
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    I haven't changed the blade in over 18 months . . . No Problems !
  20. threeputt
    3,389
    1
    38
    Mar 10, 2006
    washington state
    SignWorks is probably on to it. Be certain, absolutely certain, you're not using the long clamps when you sheet cut.
    But by all means use this feature, that's what it's there for. No Box Knives!
