Versacamm Pinch Roll Error
Discussion in 'Roland' started by All Star Graphics, Jul 16, 2009.
  1. All Star Graphics
    All Star Graphics Member
    74
    Nov 10, 2008
    Glen Burnie, MD
    Was wondering if anyone else has gotten pinch roll errors when the pinch rollers are in the right place. The sensor seems like it is working to some capacity because it pauses like it is reading the "left" (our right) roller. It just bypasses the other end comes back and gives an error message.
  2. CS-SignSupply
    CS-SignSupply Very Active Member
    Cut Carriage Cable, Cut Carriage board, Pinch Roller Sensor... could be any of these
    My 2 cents, replace the cut carriage cable and 2 mylar guides.
  3. Pacific Coast Sign
    Pacific Coast Sign Active Member
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    You have a bad cut carriage cable.... 99% for sure! Replace the cable (1/2" flat white wires, and the 2 plastic guides . Usually the guides get ink or dirty and begin to stick to the cable..this starts the cable to "slap" and break the wires inside...this is why you may be able to have it work for a minute...then fail the next...or completely fail all together. Be SURE to UNPLUG your printer before doing ANY electrical work!!!
  4. Northern Design
    Northern Design Northern Design Graphics
    83
    2
    8
    Jan 1, 2009
    seattle
    pinch roller
    The problem is the sensor is covered in residue from over spray. Do you have any rust colored overspray residue on the print carriage? this is the sign
  5. hjlanda22
    hjlanda22 Member
    81
    I have the same issue, however i rubbed the sensor eye and like magic it worked! however this is an ongoing problem and i believe it is a temp fix.
    My question is where can we buy the cut carriage able and the guides that sit around it?
    Any sources?
  6. Pacific Coast Sign
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    Give can me a call if you like, I can help with your parts and give you advise about installing the cable...and be SURE to UNPLUG your printer before doing ANY electrical work. I think the cable is about $20-$30 and the guides are $5-$8 each...pretty cheap. Or you can call your local Roland Dealer for the parts and advise.
  7. Ken
    Ken Major Contributor
    5,484
    2
    38
    Feb 7, 2005
    BC
    I have a ribbon cable for an SP 540..cheap! $20 bucks plus shipping. Never used..they sent me the wrong one and no return was necessary...So ,if it is of use to you..let me know. Ummm..not sure if the Mylar cover strips included..probably, I can check if you are interested.
    Ken
  8. All Star Graphics
    74
    Nov 10, 2008
    Glen Burnie, MD
    I was able to finaggle it and make it work for a little while. It finally went completely up yesterday. I forgot that I posted and in a panic called my dealer/tech $317 to fix this $22 part. It hurt but I'm back making money. Thank you all for your offers of help!!!!:U Rock:
  9. Pacific Coast Sign
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    I hope the dealer cleaned the area of ink and dirt...this is something you can do to help extend the life. Once the guides get sticky with ink/dirt they grab onto the cable then start to "slap" back and forth breaking the wires inside the cable. Keep the area clean and your printer will perform best. Use alcohol to clean the area and watch out for your encoder strip not to get dirty.
