VersaCAMM Printing Speed
Discussion in 'Roland' started by neftali, Nov 6, 2004.
  1. neftali
    neftali New Member
    8
    Oct 25, 2004
    Puerto Rico
    :Oops: I want to know what is the VersaCAMM Printing Speeds @ different resolutions. Roland don't provide that information in the specification of the printer.
    :thumb: Thanks,
    Neftali Hernandez
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,917
    544
    113
    Sep 11, 2003
    Olympia, WA
    I think that information is in their printed brochure and if memory serves me correctly the print throughput at 720 x 720 was just under 40 square feet an hour.
  3. arbys
    arbys Member
    64
    I read in the latest digital graphics about the (ahem)virtues of liquid laminates and
    it mentioned that solvent prints need time to cure before applying a flim laminate, otherwise the remaining solvent in the print will gas out and make bubbles, just like applying vinyl to a vehicle with an uncured paintjob. My question is how long do you have to wait for the VC? And would you have to wait a longer or shorter period of time for true solvent? Just curious.
  4. neftali
    neftali New Member
    8
    Oct 25, 2004
    Puerto Rico
    Finally I got the answer.
    Finally I got the answer here it is:
    <TABLE style="WIDTH: 240pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=320 border=0 x:str><COLGROUP><COL style="WIDTH: 54pt; mso-width-source: userset; mso-width-alt: 2633" width=72><COL style="WIDTH: 47pt; mso-width-source: userset; mso-width-alt: 2304" width=63><COL style="WIDTH: 41pt; mso-width-source: userset; mso-width-alt: 1974" width=54><COL style="WIDTH: 98pt; mso-width-source: userset; mso-width-alt: 4790" width=131><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: black 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-BOTTOM-COLOR: #c0c0c0; BORDER-LEFT: windowtext 1pt solid; WIDTH: 240pt; HEIGHT: 12.75pt; BACKGROUND-COLOR: navy" width=320 colSpan=4 height=17>
    VersaCamm SP-300 Print Speeds
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 54pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: #3366ff" width=72 height=17>Resolution</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT-COLOR: windowtext; WIDTH: 47pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #3366ff" width=63>Direction</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT-COLOR: windowtext; WIDTH: 41pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #3366ff" width=54>Passes</TD><TD class=xl23 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT-COLOR: windowtext; WIDTH: 98pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #3366ff" width=131>Square feet per hour</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl22 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 54pt; BORDER-TOP-COLOR: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: silver" width=72 height=17>
    360 X 720
    </TD><TD class=xl22 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-LEFT-COLOR: windowtext; WIDTH: 47pt; BORDER-TOP-COLOR: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: silver" width=63>
    bi
    </TD><TD class=xl22 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-LEFT-COLOR: windowtext; WIDTH: 41pt; BORDER-TOP-COLOR: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: silver" width=54 x:num>
    8
    </TD><TD class=xl22 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-LEFT-COLOR: windowtext; WIDTH: 98pt; BORDER-TOP-COLOR: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: silver" width=131 x:num>
    63
    360 X 720
    uni
    8
    32
    720 x 720
    bi
    16
    19
    720 x 1440
    bi
    32
    9.5
    </TD></TR></TBODY></TABLE>
    Pretty slow. What you think? I think I will wait for the VersaCamm SP-540V -54"
    that has print speeds of 119 sf/h at 360x720.
  5. Fred Weiss
    20,917
    544
    113
    Sep 11, 2003
    Olympia, WA
    I think I was recalling the Mutoh Jr. specs. Yes that is pretty slow.
  6. paul luszcz
    paul luszcz Active Member
    521
    3
    18
    Feb 4, 2004
    Massachusetts
    I asked Roland this question at the USSC show because we're considering purchasing a solvent printer.
    The Versa Camm is really slow.
    In uni directional print mode it runs at 39 sf/hour at 360 x 720 dpi and 18 sf/hour at 720 x 720.
    This compares to the SolJet (and our CJ) 540 EX speeds of 78 and 39 respectively, in other words half the speed.
    Be careful when comparing print speeds. Roland printers (and others I'm sure) do not print well in bi-directional mode. Doing so nearly doubles the print speed, which is why you've heard numbers over 100, but produces unacceptable (to me) banding.
    We find the CammJet speeds (which are the same as the SolJet) very acceptable for our volume, but would have trouble at the Versa Camm speeds.
    Mutoh claims its Falcon Outdoor (and Outdoor Jr.) is as fast as a SolJet, but my dealer advises I take that with a grain of salt. I don't know first hand whether the Mutoh quality is acceptable at its rated speeds.
  7. Baz
    Baz Very Active Member
    Im printing with an original Soljet ... 90% of my prints are done at Fine2(540dpi) bidirectional. I get verry minimal banding. I never get any comments from customers about banding, seems im the only one who notices it.
    Proper cleaning and calibration is the trick.
    Since my printing speed is slower then the 540EX model, maybee that is why i dont get much banding.
    As long as i can crank out a 4x8 in an hour, at the moment im a happy camper :). As the bisness grows, i will have to upgrade because of the speed issue.
  8. paul luszcz
    521
    3
    18
    Feb 4, 2004
    Massachusetts
    Your printer is effectively running at the same speed as mine, although I'm running 720 dpi unidirectional.
    I also find that speed acceptable, and run at 360 by 720, which is twice as fast, when I need faster throughput.
    It's half that speed (the VersaCamm uni-directional mode) that worries me.
  9. Barry
    Barry Active Member
    659
    May 6, 2004
    99% of my printing on my Versacamm is done in bi-directional mode and I have never had problems with banding. If Versacamm prints have bands in them something is wrong with your profile, either to much or not enough ink or wrong heat setting.
    Here is a link to a 40x30 photo print (On metamark vinyl) I did a week or so ago, not one band in it. Was printed at 1440x720 bi-directional.
    http://www.mustangmods.com/data/1/ajphoto.jpg
  10. SteveB
    SteveB New Member
    18
    Nice print Barry - Looks like you've got the hang of it!
  11. Barry
    Barry Active Member
    659
    May 6, 2004
    It takes a few months to really get the feel of how things are going to print. Once you played with it enough, its pretty easy to get all the settings set properly.
  12. DigitalFusion
    DigitalFusion New Member
    7
    you can also set the head speed on ther versacamm to 1000 from the default of 500 which should help speed things up
