VersaCAMM SP-300i Question
Discussion in 'Roland' started by Sagan4862, Oct 17, 2012.
  1. Sagan4862
    Sagan4862 Member
    25
    I know this device has print and contour cut capabilities, but i was wondering if you can use the cut function to cut other media with. For example say i wanted to cut plain black vinyl could i use this machine or would i have to use a separate plotter? Thanks
  2. tomence
    tomence Very Active Member
    1,647
    25
    48
    Feb 10, 2009
    IL
    Yes you can use it as a separate cutter to cut
  3. john1
    john1 Guest
    yep
  4. SuncitySigns
    SuncitySigns Member
    168
    Yep easy..... Just pit what ever colour you want in and send through the file with a cut line around whatever an use the the cutfile in your rip program, I do it with mine a bit.
