Versacamm SP-540V barely printing after move...
Tony Rome
I just moved this from one room to the other.
I did not drain lines or anything.
I manually cleaned, I auto cleaned all it does is print very VERY faint black.
Any suggestions?
THANKS!
artbot
after doing the cleaning, is there the usual amount of latent ink in the caps? and have you monitored the waste tubes during pumping? also, is the printer level?
Tony Rome
Not sure how to check latent thing but I did barely use it for 2 days and had it powered off during those days I think that was bad
artbot
i'm just wondering if you've proven that you are getting proper supply. even rows of ink sitting in your caps is the quickest way to estimate ink supply.
